Results 11 to 20 of 21
Thread: Why does your car vibrate after giving it a lift
    Match the uni joints at both ends. Sit the both either vertical or horizontal at the same time when fitting the tail shaft.
    Thanks mud. I'm pretty sure mine is out. How do I re align? Do I have to pull out the shaft from the little end from the big one and then reinsert?
  2. #12
    Quote Originally Posted by timmay556 View Post
    Just take the 4 bolts out at the joint between the Unit and the Pinon and rotate to alignment and refit the bolts. 10 minutes max and no need to dismantle anything.
  3. #13
    Added extra video Toddy...
  4. The Following 2 Users Say Thank You to AB For This Useful Post:
    MudRunnerTD (13th July 2014), NissanGQ4.2 (13th July 2014)
  5. #14
    Surely that won't work. As the two ends of the tail shaft have a splined joint you can't rotate.. Otherwise the tail shaft wouldn't work.
  6. #15
    Nov 2014
    Waikiki, WA
    Totally agree timmay.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  7. #16
    yeah come one MR! get your story straight mate!!!
    nah think about it guys, it totally makes sense. you should still be able to rotate the tail shaft from the other end?? with the gearbox in neutral etc?
  8. #17
    Nov 2014
    Waikiki, WA
    The only way to align the universals so the spigots are identical position either end is to rotate shaft on the splines. You may have to have your tail shaft rebalanced.
  9. #18
    Dec 2014
    Russia
    And if you try to put the CV joints?
  10. #19
    Beginner Convert's Avatar
    Dec 2019
    Ive been getting a real clunk in the drive train recently and got under the y60 shorty today for a look.
    the Diff backlash was clunky and so was the transfer gears but what surprised me was the sound in the drive shaft spline.
    I greased the spline via the nipple and the clunk is gone now.
    Just goes to show that even if the rear diff has wear in the spiders, that spine can be the actual problem.
    Id say the drive shaft spline is probably worn out though.
    Purchased a good second hand front diff head for it today as there was a tad too many big bits on the magnet last oil change and will do the rear as well as the drive shaft.
    Good thing about these trucks is that the parts dont break the bank
  11. #20
    82 Post(s)
    Do not click on the previous posts link!! Pricks are getting clever.
  12. The Following User Says Thank You to mudnut For This Useful Post:
    MudRunnerTD (18th July 2022)
