Results 1 to 7 of 7
Thread: internal fuse box
    Advanced scubasteve's Avatar
    Redland Bay, QLD, AUS
    internal fuse box
    Im having troubles with my indicators and headlights and they seem to play up when I fiddle in the fuse box. It looks like there's been a blow out and the box is all white and oxidized. Does anybody think it would be possible to clean up the damage or am I going to need to rewire a new fuse box in? If so how hard would this be? Ill get some pics in the morning so show what I mean
    1989 Ford Maverick: TB42s Carby, Snorkel, 3" king spring suspension lift, 2" body lift, aftermarket extractors, 33x12.5 mickey t MTZ's, 2.5: Sports Exhaust
    84 Post(s)
    It depends on what you find when you take the screws out and see what has caused the problem. Moisture may have caused some cables to corrode and make the joints a high resistance, which heats up under load.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    scubasteve (9th July 2014)
    Oct 2013
    Port Hedland
    Grab a can of contact cleaner give it a good spray let it evaporate then try it.
  5. The Following User Says Thank You to cjb For This Useful Post:
    I pulled it off yesterday and all the wires and terminations seem to look ok I couldnt get my head right in there but it looked like it was only the front face was damaged. Ill track down some contact cleaner and give it a blast and see if that helps
    Quote Originally Posted by cjb View Post
    Gave that a try today it cleaned up ok but didnt solve my problem
    After pulling it off again and having a fiddle the connections in the back seem really dodge the headlights flicker when the cables move and theres alot of arcing and carrying on so im trying to figure out my best option. I think I may have to transplant a new fuse box in and redo some wire connections
    brisbane
    Can you just cut and replace or solder the existing wires and heat shrink and put them back?
    Quote Originally Posted by megatexture View Post
    Thata what I think ill have to do. Im going to look at maybe an aftermarket fuse box and extending the loom a little and putting it up under the dash. Just an idea tho
