Results 1 to 10 of 19
Thread: Limp mode or something else?
    Whyalla SA
    GU IV 2005 DZ30Di
    On the last trip home I wend to pass a B-double. Dropped back to 4th and hit the accelerator. Started to pass then nothing, no power. Foot off accelerator, down again all back to normal. Not a nice experience on a 2 lane highway.
    No dash light I noticed and have NADS. Set to 15 psi.
    No I was not looking at the dash. When you hit 110+km/h and passing a B-double the last thing you look at is the dash. Engine sounded ok and was pulling well till that hit. The only thing I can think off is I was getting close to the red line. I've hit that red line before and not had issues. From engine sounds not possible.
    Got home and cleaned the MAF but this still does not make sense.
    This was about 200km into a 400km trip so makes little sense. No problems after this either.
    All a sort of one off nasty.
    Any suggestions will be useful.
    476 Post(s)
    Limp mode mate. Either your MAF is on its way out or your Dawes is set right on the line of Limp mode and only when you really push the engine real hard your boost may just top over the Dawes set limit. Maybe just enough to set limp mode off.
    Whyalla SA
    I will have to check service records but I thought I had put in a new MAF about a year ago, that replaced the original one. failing that new MAF.
    Boost is set to 15 psi so the Dawes valve settings should not come into this I hope.
    The parol does 110km/h happily but I have not pushed it at this speed in 4th gear lately. I normally start overtaking in 4th then flick to 5th at about 120 km/h. then shoot off at 130km/h. in this case dropped out as I started so about 115 km/h in 4th. Seldom hit really high revs.
    Anyway back to service centre with it.
    I might suspect old MAF and time for a new one.
    Throw in an adjustable drag link and this cost to run as much as a mistress..
    (At least patrol doesn't answer back or nag.)
    Advanced Pokey's Avatar
    Mar 2014
    Tassie
    My Dawes is set at about 14.5 to avoid limp while im waiting for my maf voltage modifier to be replaced. A couple of times I've hit limp mode. I've seen 17 psi on a cold night. It goes against the theory of a dawes but it seems the colder/denser air the more boost it will allow. Early mornings consistently see a brief 16 and power is better but know limp mode is close. Maybe yours did hit limp because its set close to the limit. Just a thought also is the spring in the dawes is metal. Metal changes characteristics with heat......
    I plan to live forever................going well so far
    476 Post(s)
    As pokey just mentioned, he has his set to 14.5psi. Some Patrols can only handle 14-15psi before limp mode, then I have fitted kits to Patrols that still didn't see limp mode at 18psi!
    Its going to be either I suggested I reckon. Dud maf, again, or the dawes is on its limits.
    Plus you don't need to see high revs to max out the Dawes. Just a heavy foot will do...
    How often do you clean the MAF too BTW? Do you use MAF cleaner or something else?
  6. #6
    If you say you think it redlined I would say it shut down as an engine protect feature
  7. #7
    476 Post(s)
    didn't know they had such a feature John. I have redlined mine a few times and nothing happened. Might be different on later models...
  8. #8
    pretty sure they have an over rev thingy , read it somewhere
    Mine did it once when selecting lower gear and forgetting about it
  9. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (27th May 2014)
  10. #9
    Whyalla SA
    I had every thing checked 600Km before this occurred. MAF cleaned as well.
    MAF cleaned every 5000Km.
    It could be a simple case of having the boost accidentally set a over 15psi on the last check.
    It had been OK for the last year, and has not occurred again, so just seems an odd thing.
    I have red lined before and nothing has happened, no power loss.
    So if the systems hits limp mode, which lights are supposed to come on?
    I didn’t notice anything in this case.
    Anyway back to workshop tomorrow for a recheck and test.
    Need them to check a bit of oil on the intercooler intake pipe and some oil marks at the back under the intercooler. Some may be old stains before I dumped the Nissan intercooler.
  11. #10
    476 Post(s)
    Quote Originally Posted by outback View Post
    No lights will come on when you hit limp mode....Oil in the intercooler is normal, sort of. It comes from the crank case vent tube that runs from the top of the motor and back into the air intake. To overcome this you install a catch can to filter the vapors before they enter the air intake.
