Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Uhf interferance if connect another accessory?
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I would be wiring it to the AUX battery via a suitable fuse as suggested , leave your start battery for that, just starting.
    Don't need a flat battery out in the Simmo
    Check condition of both batteries if any are older than 3years I'd be looking at swapping it for a new one.
    You don't need any dramas out the middle of no where
    Perhaps wire a relay in to accessory so you don't have to remember to turn it off.
    Lucus30's 1999 GU ST TB45E
  2. #12
    Quote Originally Posted by lucus30 View Post
    I'll give you a hand next weekend if you want
    Thank you mate, appreciate it...ill be under the pump getting everything ready for the arvo cook up and pizza base prep.
  3. #13
    Apr 2011
    Melton
    re your orginal question:-
    We have had some issues with sat phone kits casing interferance at 150Mhz.
    if you find that your cb rx souns noisy or you seem to have trouble receiving - try disconnecting the sat kit to see if thee is a differance. (uhf cb is at 476Mhz)
  4. The Following User Says Thank You to GQ TANK For This Useful Post:
    AB (27th May 2014)
