Results 1 to 6 of 6
Thread: fuel transfer pump: same for diesel or petrol?
    Advanced brynk's Avatar
    Mar 2011
    g'day folks
    i'm planning a petrol conversion on my diesel one of these days, and i was wondering if anyone can confirm that the transfer pump in the diesels is the same as the transfer pump in the petrols?
    thanks in advance
    r's brynk
    Hey mate, do you mean are the fuel pumps the same or the transfer sub tank pump?
    Just confirming what conversion you are actually doing, are you converting a diesel td42, 2.8 or 3 litre to a petrol engine and what vehicle?
    What engine are you going to and what do you have currently?
    What AB said, Cobber... we need more info to answer your Q
    Mar 2011
    doh i can see i didn't give enough info, sorry
    i'm thinking about transferring a rd28 to a petrol engine (at this stage, possibly the ford 4.0l turbocharged inline 6)
    i'm wondering if the transfer fuel pump between the sub and the main tanks is the same between the diesel and the petrol patrols (ie, can i leave the tanks in place and pump petrol from sub to main without concern)
    i'm expecting the sender unit from the main tank to the fuel rail will need to be upgraded to a higher-pressure unit, for the e.f.i. engine
    Patrol God Stropp's Avatar
    38 Post(s)
    Mate between the two tanks as long as it pumps is no problem and as you say the xr6t will need an upgraded pump.
  6. The Following User Says Thank You to Stropp For This Useful Post:
    brynk (10th February 2014)
    Feb 2014
    diesel pumps are different, they use the diesel to lube the pump so i would think the pump will burn out if used for petrol.
