Results 1 to 7 of 7
Thread: Fuel gauge not working in my mav
    Advanced elmo4eva's Avatar
    Dec 2013
    Hey all just wondering how to fix a fuel gauge its not working
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Start by checking the fuse for the warning lamps and gauges. Does it have power on both sides of the fuse with the ignition on?
    Do the other gauges and warning lights in the instrument cluster work?
    In the rear floor, above the fuel tank, there is an inspection plate. This enables access to the fuel sender without having to drop the fuel tank. Remove this cover and you will see the wires for the fuel gauge....should be a yellow with a black trace wire and a black wire. Disconnect the plug from the fuel tank and with some wire or paper clip (just don't damage the pins in the plug) join the yellow with a black trace wire and the black wire together. Ignition on the fuel gauge should now read full? if it doesn't try connection the yellow with a black trace wire straight to ground.
    If the gauge does read full you will need to remove the fuel sender unit from the tank and make sure the float is still connected and hasn't fallen off. Then perform resistance checks as per attachment.
    If the gauge doesn't read full you will need to remove the instrument cluster and check continuity of the yellow with a black trace wire.
  3. The Following 3 Users Say Thank You to Yendor For This Useful Post:
    93patrol (31st December 2013), Bigcol (31st December 2013), jack (31st December 2013)
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    your a bloody guru Yendor
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Quote Originally Posted by 93patrol View Post
    Never ceases to amaze me
    Jack
    2024 Isuzu MUX
    Aug 2010
    adelaide
    what about a bad earth
    OH LEATHER IS NICE
    Dec 2013
    hey mate yer i checked that i had a yellow wire with a green trace and a plane yellow wire and a earth only thing worked wen i put the yellow and green wire together with the eath as the fuel light and when i checked the yellow and earth the gauge went up so u think i should check the fuel sensor
  8. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yes you will need to pull the fuel sender out and check it.
    Your fuel gauge reading full when you joined the Yellow wire and earth together means that everything is good from the fuel gauge down to the tank (don't worry about the colour being slightly different, wiring diagrams aren't always correct).
    The low fuel light coming on when you joined the Yellow with a green trace wire to earth is normal.
    Cheers Rodney
  9. The Following User Says Thank You to Yendor For This Useful Post:
    elmo4eva (5th January 2014)
