Results 1 to 10 of 12
Thread: Electric exhaust brake
    Eagleby Queensland
    Hi guys, anyone had dealings with a bolt on for safer decent towing
    Its a ZD 30 IV 2007 CRD Auto, electronic rather than vacuum cheers
    I posed this question after I first joined , seems its way too expensive from memory
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Exhaust brake wouldn't work too well on an auto. Spend your money on better rotors, pads and callipers if you want better braking.
    He may mean better engine braking, but better rotors and pads
    do help heaps as I've just changed to dimple drilled and slotted all around
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Seanz (30th December 2013)
    Eagleby Queensland
    Hi guys, stopping is not the problem its traveling down
    hills, engine braking would be nice after coming from a manual
    84 Post(s)
    Is it not advisable to drop the auto back a few cogs, or does it do damage in the long term?? I used to put the old falcon sludge box into second, coming down through the Black Forest and it seemed to handle it ok.
  8. #7
    NT
    Depending on the vehicle though, it often will often change down and continue the same speed but higher rpm. Some newer auto vehicles have smarts where they control the engine (with three of four presses of the brake pedal going downhill) (by retarding timing? to produce a slight engine braking effect).
    How does an auto patrol handle downhill if you change back?
  9. The Following User Says Thank You to P4trol For This Useful Post:
    mudnut (30th December 2013)
  10. #8
    Seeing as it is the flavour of the week topic... A switch to lock the TC means you then have the engine braking of a manual tranny. Worked gangbusters on my GQ and made a big difference
  11. The Following User Says Thank You to the evil twin For This Useful Post:
  12. #9
    Eagleby Queensland
    The dropping back is ok I just thought of higher oil temperature in gear box over long
    Hauls down steep inclines but yes placing back to lower gear works
  13. #10
    Apr 2013
    what is the "TC" and what is the switch for the gq ?
    the one thing wrong with middle age ...is knowing you will grow out of it !
