I've pressed restore to see what'll happen so fingers crossed.............
Is smoke meant to come out??
IF YA DONT GET STUCK YA AINT TRYIN HARD ENOUGH........OR YA TOOK THE CHICKEN TRACK![]()
Avo (18th August 2013), NissanGQ4.2 (18th August 2013)
X 2.
I will probably be because the automatic IP address leased to it via the DHCP server in your router has a problem when your printer goes into standby.
I would definitely be reading the manual and allocating a static IP address to the printer (via printer settings). Make sure you set it beyond the IP range of the DHCP table in your router (modem).
Post up your printer and router model and I'll see how I go stepping you though the process.
Tip tip tip......tap tap tap....
OK so i downloaded a manual and i got a pop up saying that my Win Zip was expired and would i like to purchase it. Well i must have originally just got a trial version from somewhere when i downloaded the gq manual last year. So what do i do? I dont wanna pay for dat sh1t! Ill more than likely only use it once in the next year or so.
Is there anyway to unZip the GU manual without purchasing WinZip???
(Ive got good, fast internet so i reckon it wouldnt take long to download an unzipped file if one was available)
Hello from Under Down Under!
Try this Lucas
http://winzip.com/win/en/prodpagewz-...0WinZip%20Free
taslucas (25th September 2013)
7zip Lucas.....Then you can make and extract RAR files, way better then winzip and zip files.
I can compress 200mb 3dmax files down to about 10mb.
