Page 52 of 116 FirstFirst ... 5051525354 ... LastLast
Results 511 to 520 of 1157
Thread: Winnies 747 TD42 GQ
  1. #511
    477 Post(s)
    I just wanna hear the awesomeness of your rig again Winnie.
    Don't worry about em Winnie I like you regardless. Secret TD42 business
    You guys make me jealous, and sick.
    Winnie (13th August 2013)
  3. #512
    Okay so temps are down 50 degrees on the freeway, so when cruising at 110km/h they sit at 250, going up the hill to my house it does not get above 380, used to get to 450.
    You know what that means, dump more fuel in! lmao can't wait until next Tuesday!
  4. #513
    North brissy
    Have you got the scoop on now?
  5. #514
    Yeah its on and looks awesome. The scoop is way bigger than the actual hole for the cooler though... Seems a bit pointless.
  6. #515
    334 Post(s)
    Yes he has but he is not sharing wont show anyone until after the meetup! Bloody kill joy!
  7. #516
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    It's all for looks anyway, scoops don't do anything, just ask TD. Lmao
    Hello from Under Down Under!
  8. #517
    334 Post(s)
    Hmmmmm?? Is the hole the same size as the Intercooler ??? That's the point!
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Winnie (15th August 2013)
  10. #518
    Yep even though the scoop dropped my temps by 100 degrees, it's not doing anything!
  11. The Following User Says Thank You to Winnie For This Useful Post:
    taslucas (15th August 2013)
  12. #519
    Yeah it is and it seals up but the scoop is far bigger
  13. #520
    334 Post(s)
    Then that's fine mate, if anything it should cause more pressure under the scoop and force more air through as its catching more that the hole can handle in a 1 to 1 flow rate I would think?
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    threedogs (15th August 2013)
