Results 1 to 4 of 4
Thread: Front quater
    Advanced Maxgq's Avatar
    Mar 2013
    nunawading, Vic
    Front quater
    How do you remove the front panel?
    *TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
    Lift the bonnet and you will see a row of bolts.
    Open drivers door and there is a couple more
    Remove the inner guard from the wheel arch and there is a cople more.
    20minutes tops to pull it off the first time mate.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Maxgq (29th July 2013)
    Mar 2013
    nunawading, Vic
    Its the left side, so snorkel first but oh well, that's no worry, thanks for your help
    Quote Originally Posted by Maxgq View Post
    What do you need to Take it off for?
    Just undo the mount for the snorkel on the A pillar and leave it on the quarter panel and remove the whole thing. There is a big hose clamp on the snorkel inlet inside the guard that you will undo once you take out the net guard.
    Hope that helps. Simple mate.
    Maxgq (15th August 2013)
