Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: Diff oil smell
    Patrol Freak Rustyboner81's Avatar
    Perth
    Clunk if you do end up doing some work on it in the driveway give me a call (if you still got my number) i'll give you a hand if you need it.
    But im back next thursday
    Sent from my GT-I9305T using Motorculture mobile app
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  2. The Following User Says Thank You to Rustyboner81 For This Useful Post:
    Clunk (24th July 2013)
  3. #12
    Quote Originally Posted by Westy's Accessories View Post
    Are there outside and inside seals in the rear diff also?
    Yes there are, the inner seals (axle seals) are easy to replace in the rear.
  4. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    BigRAWesty (24th July 2013), Clunk (24th July 2013)
  5. #13
    Perth
    been thinking....sure its gear oil and not cooked wheel bearing grease?
  6. #14
    Rear diff breather or ARB rear air locker fitted??
  7. #15
    Jul 2013
    repair asap or it could possibly get into the breaks and mess up your breaks aswell meaning more money to be spent !!
  8. #16
    Quote Originally Posted by Rustyboner81 View Post
    Note sure what wheel bearing grease smells like. Not done them before.
    My folks went to the Google Play Store and all they got me was this lousy Motorculture App!!!!!!!
  9. #17
    Negative on both TD
  10. #18
    It's not oil dripping down the back of your motor, that's hard to pick up just by lifting the bonnet.
    Would have tell tale signs underneath if it was leaking from there.
  11. #19
    smell is definitely coming from the rear drivers side only, can only smell it from the outside of the car. Oil level in the diff appears to be just fine and still no visible signs for leakage on the brake backing plates or anywhere in that vicinity. some days the smell is stronger than others.
    so could possibly be what russ has suggested!!!!!!?????? but it does smell very much like diff oil.
  12. #20
    Maybe if you have diff breathers fitted the tube is broken or if OE its only an inverted cup on rubber hose, bound to smell.
    I'd probable look in the diff breather area, and maybe change rear diff oil.
    Hard for smell to come through steel diff housing.
