Page 5 of 30 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 293
Thread: Member on hard times parts list
  1. #41
    Legendary Alitis007's Avatar
    15 Post(s)
    From the front page for interest
    Took a minute to jerry what was going on but thanks for adding Daz!!
  2. #42
    15 Post(s)
    Just making a list of the parts we will need and would like to have for our Member on hard times thread. Theres going to be a wish list or goodies list and a need list that i will be updating as we go along.
    PLEASE ONLY POST HERE IF YOU HAVE PARTS THAT YOU WILL LIKE TO DONATE OR THAT YOU THINK WILL BE A GOOD IDEA FOR THE GOODIES LIST!!
    The car is an 01 GU ZD30 ( Built date 6/2000)
    WHAT IS NEEDED
    GEARBOX / synchromesh kit (4th gear ) -
    Clutch kit - ordered
    Rear main seal OEM -
    Rear diff - donated by Nissannewby
    Recovery points - donated by Threedogs
    Battery - donated by Mudski
    Oils : Front diff 80w90 up to 5.4 liters -
    Rear diff 140w ( or 85w140) up to 4.7 liters -
    Transfer case TX12A ( 75w90) 1.9 liters -
    Gear box TX12A (75w90 ) 3.5 liters -
    2 X Swivel hub kits and bearings ( bearings felt good but need to look for pitting and metal filings ) -
    Rear stabilizer bar link rods, long and short ( 2" lift) -
    Rags, rags, RAGS!!!! And paper towel - Healy, BA
    HTB / High Temp Bearing grease -
    Brake fluid ( DOT 4) - 2 X 500ml -Plasnart
    CV / Constant velocity grease -
    SAFETY EQUIPMENT
    Jack stands - MR 1 set
    Trolley jacks - MR 2 x 2000kgs jacks
    Wheel chock's -
    Safety glasses - MR has Heaps
    Gloves ?? Leather and silicon / rubber - MR will bring a box of Nitriles (100)
    Hand cleaner ( Good stuff/ Jiff works too) - Alitis007 (i can get some for free but won't be to AB's till late)
    WISH / GOODIES LIST
    To be revealed - Westy's accessories
    Rear work light with mounting stand -
    Rock sliders (the ally side steps look fantastic ATM) -
    Wheel arch flares and rear bar with moulded flares (sorry mate it looks anorexic lol) -
    Spotlights ( who was showing them off the other day ????) -
    Tools
    Like i said i will add more to this list daily!
    Thank you for all your help and support!!
    And a big thank you to Bloodyaussie / Jonathan for organizing this special event!!
    Here is where we are at for the moment!
  3. #43
    Oct 2011
    Essendon
    Guys, how much/what electrical work is required?
    Need to make sure I have enough corrugated conduit/cable ties/terminals etc.
    Switches?
    Cheers,
    Drew
    Tip tip tip......tap tap tap....
  4. #44
    15 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    Switches?
    Cheers,
    Drew
    Not sure about switches but will need wire, electrical tape, heat shrink, soldiering iron and soldier plus what you got mate! Later on i'll add to the list
  5. #45
    Re: Member on hard times parts list
    I can get a pack of electrical tape and a few lengths of heat shrink in different colours. Consider that my contribution. Remember I work at an electrical wholesaler but we don't do 12V stuff, I will donate what I can.
    If you're happy and you know it tap a post!
  6. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Alitis007 (24th March 2013), Drewboyaus (24th March 2013)
  7. #46
    333 Post(s)
    I have converted all my switches to Carling style switches and have a Heap of 12v switches that i am probably going to throw out as i will never use them. I will bring them along and your welcome to what ever is there
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  9. #47
    Oct 2011
    Essendon
    I've got a bag of 10,000 Heat stabilised cable ties, some split conduit, a few various terminals my soldering iron, solder and some wire but might need more depending on what we need to do.
    George (or anyone), are you able to get your hands on some cheap 12V wire (4mm)?
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
  11. #48
    15 Post(s)
    Chris wire is wire, cars use 10amp mainly and 15 amp wire generally but i'm not sure if 12v is different to 240v but i do know that the wire used in the house walls is rated 10 amp but is 15 amp wire if that makes sense?? Even tho most power points are 10 amp they under rate. When i go to work on monday i'll look at a spool and post a pic of its specs.
    Heat shrink is a hard one but i do know Narva make a small pack with red and black with different gauge heat shrink like .9mm, 2mm, 3.4mm etc etc so sort of pack like that would be fantastic
  12. #49
    15 Post(s)
    Lets see what Chris has at his work and figure it out on monday night??
  13. #50
    Sorry George wire is not wire. Automotive cables will be required. Housing wire has much thicker stranding and will not be up to the punisment of corrugated roads and will break.
  14. The Following User Says Thank You to Winnie For This Useful Post:
    Yendor (24th March 2013)
