Results 1 to 10 of 12
Thread: no clutch or gears
    Nov 2012
    Qld
    no clutch or gears
    hi everyone , i was down town today & when i went to come home i had no clutch. i topped up the oil & it was running out from between the engine & the gearbox. now the gear stick just slops around also. anyone got any ideas ?
    How's the serenity boots's Avatar
    Sep 2011
    So did you top up the gearbox with oil or did you top up the clutch master cylinder with brake fluid ?
    The price of excellence is dicipline , the cost of mediocrity is dissapointment .
  3. The Following User Says Thank You to boots For This Useful Post:
    panther (12th March 2013)
    Nov 2012
    Qld
    i topped up the engine oil & noticed it leaking between the engine & the gearbox. i have just had it towed home & have noticed all the clutch fluid has run out of the cylinder which was full the other day when i checked everything
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    What engine and transmission mate? How fast is the engine oil running out? Does the clutch have feeling after topping up the clutch fluid?
    Hello from Under Down Under!
  6. The Following User Says Thank You to taslucas For This Useful Post:
    panther (13th March 2013)
    Expert Dominator's Avatar
    Oct 2011
    no clutch or gears
    Sounds like your clutch slave cylinder is leaking.
  8. The Following User Says Thank You to Dominator For This Useful Post:
  9. #6
    Sep 2011
    Well panther it sounds like you've done a rear main oil seal on the engine . All that oil leaking has maybe damaged your clutch componentary.
  10. The Following User Says Thank You to boots For This Useful Post:
  11. #7
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by boots View Post
    yep that sounds right but does it explain a loose/sloppy gearstick?
  12. The Following User Says Thank You to taslucas For This Useful Post:
  13. #8
    Jan 2013
    no clutch or gears
    Could be the bush in the top of the gearbox just coincidentally broken. Pretty sure its just a plastic bush. Lost mine when i had the gearbox out the second time haha. Still drives fine. Just sloppy
  14. The Following User Says Thank You to Dales300exc For This Useful Post:
  15. #9
    Nov 2012
    Qld
    have to get clutch fluid tomorrow as its 8pm here. i will top it up and bleed it & see what happens. as for what transmission & engine i can tell u its a 5 speed manual & engine is a turbo diesel. if you need any other details i will have to look at the vehicle tomorrow. i will post what happens when i have put clutch fluid in. thanks everyone for your input
  16. #10
    Nov 2012
    Qld
    thanks to everyone for your valued input. turns out it was the clutch slave cylinder leaking & all the other oil was what had squirted out from the dust cover boot on the slave cylinder. what a job that was , you need rubber arms to get your hands up in some of them spots lol. once again this site has saved my butt & a lot of money
  17. The Following User Says Thank You to panther For This Useful Post:
    boots (13th March 2013)
