Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: turbo lag / black smoke / no power
    Expert dirtygu's Avatar
    Naire, South Australia
    Exclamation turbo lag / black smoke / no power
    hey guys well i finnaly got my patrol its a 2001 3.0ltr the guy upgraded the turbo but the car was running rough. So i got it at a good price but have since fitted a boost gauge and have found out that its not boosting past 10psi and its blowing black smoke under acceleration no idea why i have looked at heaps of threads on here and tryed a few things but cant seam to put my finger on it though maybe injector pump ???
    Re: turbo lag / black smoke / no power
    I'd be first up getting a good tune up..
    Possible over fueling I'd say. Maybe previous owner did a DIY tune..
    Owner of
    Westy's Accessories
    Legendary happygu's Avatar
    Is that upgraded the Turbo, or replaced the Turbo with a new one?
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    there is no upgrade of the turbo on a zd30 you either replace the old one or you change the turbo froma vnt to a standard turbo if it's a standard spool up type it'll need tuned if it's a vnt turbo you have a bad boost leak prob a split hose or leaky intercooler.
    Such is the rule of honour.
  5. The Following User Says Thank You to macca86 For This Useful Post:
    dirtygu (5th March 2013)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Sounds like a leak in the intercooler or the IC hoses have come off. Check where the hose comes out of the turbo. It is a common place to leak and is hard to get at.
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    Yep as stated above definatley sounds like a leaking intercooler or blown hose ect
  8. #7
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by wyld333 View Post
    yep as stated above definatley sounds like a leaking intercooler or blown hose ect
    sounds as if thats it and clean the maf with m.a.f cleaner from repco or supercheap
  9. #8
    Expert Lieney's Avatar
    Adelaide,SA
    I'd clean the MAF, pull the intercooler & all inlet hoses.
    Check for splits etc & clean the. all inside etc.
    If you're tight like me u can pull the OEM intercooler apart & use gasket adhesive to re-seal it. Works a treat.
    Check ya air cleaner, fuel filter etc
    A good engine service would be a good idea.
    06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
    Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
  10. #9
    cheers guys it is a new turbo dont know exactly if its a standard or a vnt it says its a garrett m24 so ????????? and yeas i can hear a noise sounds like a leak its coming from behind the engine possable egr pipe ???? what do i clean the inter cooler out with ?????
  11. #10
    Really need to NADS your 4x4 asap
    fit boost and EGT guages, block EGR.
    fit manual boost controller and needle valve.
    remove clean and check IC for leaks
    As suggested clean MAF check all vacuum and turbo hoses
    replace any split or perished ones
    Do you know if Chip is fitted????
  12. The Following User Says Thank You to threedogs For This Useful Post:
