Results 1 to 6 of 6
Thread: ZD30 Reconditioning vs Second-Hand Engine
    Advanced Shonky's Avatar
    Hi guys, Shonky here,
    Theo the patrol has had a pretty rough life starting out as a mining vehicle for its first 130000 K's. We almost came to the point of trading the old fella in for a newer model Kluger or Territory but came to our senses and realised we'd only be downgrading.
    The Mrs gave me the all clear to put in a TD42 in but my excitement was dashed pretty quickly after a phone call to Patrol-A-Part informed me that the engine i want to put in the 08 model could not be registered so was therefore illegal.
    My new plan is to either have my existing engine reconditioned or look for a lower K's engine that has been trashed as much.
    My question for you guys is what will give me more benefit in the long run? The money issue wont be a problem, I'd rather spend the cash to do it right the first time. I have plans to put in a custom Roo System diesel chip and 3" exhaust to help with fuel economy as well as a new 2" lift kit to help with its sagging issue.
    2008 Nissan Patrol GU 6 DX 3.0l and proud of it!
    WARNING: Using a Snatch Strap on a Tow Ball can KILL PEOPLE!
    Im pretty sure a Duramax will fit, check the archives
    Im looking for more fuel economy so im not too sure if that will help me out. I wouldnt even begin to know how much a duramax cost let alone where to buy one or install it
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Why do you want to replace the engine? is it not running or down on compression?
    334 Post(s)
    put it on a Dyno after the exhaust is done, tune it right and fit the chip and drive her until she spits a bearing!
  6. #6
    Dec 2012
    Second hand - Depending on where or who you get it from, may be worse then what you have. (Be sure to read fine print from wreckers etc)
    Reconditioned - Pricey however alot less stuffing around and the car will not be off the road as long (Warranty 3-12 month pending on where you go, Still read fine print...It may be warranty, however some do not cover costs involved)
    Reconditioning your motor - Car will be off the road for a while, can be cheaper then a second hand engine pending on how much work it needs.
    My 2 cents,
    Need prices? give me a email on what your looking at or everything if your interested.
    Regards,
    Rob
