Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Clutch question
    Sep 2011
    adelaide
    18 Post(s)
    Andy looking at what you`ve said I think the clutch may be OK it just releases at the bottom of the stroke. The light feel at the top may not be anything to worry about
  2. The Following User Says Thank You to pearcey For This Useful Post:
    Parksy (9th February 2013)
  3. #12
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I'm hoping that is the case. The piston in the slave cylinder doesn't return all the way back in the cylinder, it sits at about the halfway point. When pushing the pedal I only have half the travel to engage the clutch, hence why I thought a longer rod would solve this and ectually push the piston back all the way when the pedal is released. Tried to make it slip, but I couldn't, so I suppose I just have to get used to the pedal feel.
    Sep 2011
    adelaide
    18 Post(s)
    Andy mate the piston does not return fully as when the clutch wears it it has got to return further in to the cylinderso we do not lengthen the push rod I know there are some adjustable push rods on certain vehicles but the factory engineers know what their doing so stick with the solid rod .You will find that as the clutch wears that the release height will change and it will gradually release higher this will take a long time.
    all the best Pearcey
  5. The Following User Says Thank You to pearcey For This Useful Post:
  6. #14
    476 Post(s)
    Quote Originally Posted by pearcey View Post
    Try and find out if a clutch has been fitted. You could pull the fork boot back and see if the pressure plate is painted as genuine are not.
    Most times if the diaphragm is cracked it will slip. Also is it a boosted clutch they can some times give a very light feel at the top of the pedal
    Not entirely true that. I just replaced my GU clutch with a 4Terrain kit and the PP was unpainted... Anyway, if the clutch engages just off the floor, not much to worry about IMO. If it's gonna go, its gonna go. Pull the boot back wher ethe fork comes out and try to get some lube on the bearing carrier where it slides on the input shaft housing. Might just need a lube up.
  7. #15
    Feb 2013
    I had a very similar problem and about 2 months later the dual mass flywheel let go, so I then converted to a solid flywheel and pressure plate conversion, if its anything like mine were I had to push the pedal almost to the floor to engage then I feel you could be in a similar boat
    I also experienced a small vibration in the flywheel area while driving before the dual mass separated
    I am not a mechanic this is what happened to mine
    2001 GU PATROL, NADS, 3 INCH LIFT, ECUTALK GAUGE, YOKO GEO LANDER 33's, PEDDERS H/D SPRINGS, TOUGH DOG 45MM ADJ, TEMP & BOOST GAUGE, DUAL BATTERY VOLT METER, LIGHT-FORCE 170mm D/L, WARN HI MOUNT WINCH, BOGART'S TURBO TIMER, 3 INCH X- FORCE EXHAUST, PYRO GAUGE, SAFARI DTRONIC DIESEL CHIP, ZAPSTONE 400-490 MEG UHF
  8. #16
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers guys. I will get some lube on things as soon as I get a chance. How easy is it to do this? There isn't much room but I suppose all I need is a thin stick or long screw driver with a little grease on the end?
    I'm pretty sure the gq doesn't have a dual mass flywheel, so I'm sure I'm safe in that regards.
    Andy
  9. #17
    Feb 2013
    Quote Originally Posted by Parksy View Post
    Andy
    Sorry M8 not knowing what you are driving I guess it was of me to assume you we're driving a gu as reference was made to a gu clutch so for my input yrs and a gq does not have a dual mass
  10. #18
    Jan 2013
    Nowra NSW
    5 Post(s)
    Great advice mudski! I pulled the boot back and gave the fork pivot point a lube up. I wasn't able to reach the bearing carrier shaft to lube it, if anyone here has done this successfully tell me how you've done it. But either way, just lubing the pivot point had made a vast difference to how the clutch feels. Funnily enough it almost feels as if I've regained the full clutch pedal.
    Now that I think about it, when I mentioned that the slave cylinder piston rests at about the half way point, it's more at the 1/3 point. And even so, this shouldn't be the cause of the soft pedal because the piston isn't returning fully, I guess it's like an automatic adjustment mechanism. I'm thinking another clutch bleed and hopefully this will solve it. If not I might look at the master cylinder and try adjusting there. Hopefully this made sense...
    Andy
  11. #19
    476 Post(s)
    When the carrier is dry it will tend to stick to the input shaft housing. If you can use a long screw driver or what ever with some grease on it, and you get the grease on it, I bet it will feel much better. Something I should have done when I had the gearbox out of my GU is make a grease hose from the carrier to the bell housing. So I could grease it easily. All the prime movers use them and it would be real handy I reckon for the 4by's...
