Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Exhaust whistle?
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    Exhaust whistle?
    Hi Guys,
    Just had a new 2.75" Beaudesert exhaust fitted. I noticed that the sound was a little deeper than the stock exhaust and thought it to be normal for the 2.75".
    Today though, I noticed that when I back off the accelerator there's a very distinct whistle coming from under the car, towards the front. It sounds like air being sucked in and only happens when I back off.
    Could it be a leaking join in the exhaust?
    2012 GU8 ST 3.0 CRD. Alloy bull bar, HID spotties, Pioneer GPS/CD/DVD head unit, Beaudesert 2.75" exhaust, Autometer Boost and Pyro gauges.
    WARNING: Towballs used for recoveries can, and do, kill people and damage property.
    It's not Spool on your turbo? Is it a different sound to that?
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Lonicus (19th January 2013)
    Tewantin QLD
    Not sure mate, very high pitched and only on back off.
    Had a look and listen just then and can't pinpoint the sound. If I stand at the back it sounds like it's coming from the front and if I stand at the front it sounds like it's coming from the back. Possibly a little louder at the back though.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    if its a bolt on job maybe just needs nipping up
    or theres a pin hole in the welded joins
    you are sure its not just turbo spool up
  6. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Tewantin QLD
    It may well be turbo spool up, just never noticed it before. Boost and EGT are all fine, power is good so probably just me not knowing what is normal and what's not
    I'll go see the guys who did the exhaust and dyno on Monday and see what they say.
    Cheers guys.
    Legendary Alitis007's Avatar
    15 Post(s)
    Exhaust whistle?
    Start the car and with the help of some one block the exhaust with a rag for a few seconds, if you don't hear any fluttery noises from the exhaust gasses escaping its definitely just your turbo slowing down. Its sort of sounds like when you hum and whistle thru a tube yeh??
  9. The Following User Says Thank You to Alitis007 For This Useful Post:
  10. #7
    You'll need someone to give it a slight rev while you have your head under the bonnet, only way I found my exhaust noise. mine more like a "pitchoo" sound
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #8
    Advanced ashleylipus's Avatar
    Mill Park, Melbourne, VIC
    definitely your turbo mate.. same thing with my rd28. because these diesels aren't fitted with any kind of blow off valve like those rice burners, the un-used boost pressure when you back off the accelerator cant go forwards so it goes backwards back threw the turbo and slows the turbine down and that noise is a byproduct of that process.
  13. The Following User Says Thank You to ashleylipus For This Useful Post:
  14. #9
    Tewantin QLD
    Just went and tested a couple of things, blocked the exhaust for a few secs, no sounds of leaking plenty of pressure. No whistle when backing off if there's little to zero boost. Only when boost builds is there a whistle when backing off. On very minimal boost there's a tiny whistle for a split second just before engine hits idle speed.
    So, good call and thanks guys, looks like it's just turbo whistle and I now know what that sounds like
  15. #10
    Now if you'll have a guide to exhaust noise, drive by guages and keep ears open, my new exhaust cracked at auto trans mount{common} and right behind the turbo
