Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Been advised to Re-torque head and put Genuine H/Gasket
    FIJI
    I recently did a rebuilt on my motor and the its now heating up in long runs and not in short runs. There was no bubbles on radiator before but now when the radiator is topped up it starts throwing bubbles up and puts water into the reserve tank. but when certain amount of water goes off the radiator it stops throwing water into reserve tank and doesnt lose more water from radiator (just about 1L short of making radiator top up). I used a non-genuine head gasket during rebuild which i already had before rebuilt was done. Now my mechanic says to put a genuine head gasket in and will re-torque head. Any idea whats the torque of head bolts on TD42?? Another friend suggests me to use Chemweld to solve my problem...anyone used these before?? The Radiator shop guy told me that it can block my radiator..
    Jan 2013
    Don't use chemiweld. If you plan on keeping the car do it properly. I used an aftermarket gasket first time 40,000 k later started leaking coolant out the side, fitted a genuine one, haven't looked back.
    Your mechanic should be able to get head tensions very easily or google it and you will find.
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    You have sufficient Posts to download the Manuals Mate and the torque's are in them
  4. The Following User Says Thank You to Bob For This Useful Post:
    MudRunnerTD (16th January 2013)
    334 Post(s)
    Quote Originally Posted by Bob View Post
    Good advice Bob.
    FIJI
    ok thanks guys... i bought a Genuine H/Gasket today part no: 11044-06J00 and will give it a go and hopefully that will fix my problem of heating in long runs. just hope no issues with head.
    334 Post(s)
    Don't use chemiweld unless in the bush in an emergency to get you out.
    Is the TD42 got a Turbo on it? Is it just getting hot on a long slog up a long hill? Or on the hwy driving after an hour and it just gets hot?
    If its a long hill then maybe you have too much fuel and or not enough boost happening.
    Have you got any after market gauges fitted?
  8. #7
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    when torquing down the head make sure you follow the manuals bolt numbering procedure or you could do damage to the head
  9. #8
    FIJI
    its got aftermarket turbo (T3/T4) on a safari kit..... new turbo fuel pump fitted. i have the EGT / Boost gauges. EGT stays ok....boost abt 8psi. goes to 90-100degs when running with A/C and driving for like 20mins with bit of heavy right foot. now recently it has started to push water up the radiator when i try to top up the water.
  10. #9
    North brissy
    Get new head bolts as well. Td42 head bolts are a torque turn setting. This is where you torque to a set figure then turn the Bol an extra 90 degrees or whatever the spec says. These types of bolts are a single use item.
  11. #10
    FIJI
    The head was opened and tested ok....relief Alhumdulillah!!!!
