Results 1 to 10 of 11
Thread: Stainbauer Chip fine adjustment.... What does it do??? and does it work?
    Jul 2012
    Hobart Tasmania
    Ok so i installed a chip for my mate in a GU7, which has made a big difference but he has a stock exhaust and you can feel it holding back a bit.
    We left it stock on the +20% mark but are a bit stumped about the plus minus fine adjustment.
    What does it do ? How do you tell if it works?
    Is it like Plus minus power or just some parameter change?
    We have turned it one way, max and did not notice much difference, like wise, when turned down.
    Can someone shed some light for me.
    SHINY AND NEW: 2015 Series 2 Y62 Ti in White. Bone stock, hate to say it but its the wifes car this time.
    OLD SOLD:Silver 50th Anniversary Patrol, 2" Pro-Comp Lift, 32" MT ATZ 4 Rib, 9000lb Warn Winch, UH7700NB + BT UHF Brilliant. Ultra Gauge and some GO FAST bits........
    Jul 2012
    Hobart Tasmania
    humm no takers
    brisbane
    mate from my experience it just ups the fuel when turned to max. under load you will prob notice alot of smoke out the exhaust .
    i turned mine up once all the way and coated my trailer in unburnt diesel and soot so i turned it down a bit, its just a little trial and error to find the sweet spot
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by WogsRus View Post
    humm no takers
    Sorry mate, can't help but hopefully someone with same chip can help soon.
    ________________________
    ______ 2017 D-Max _______
    I have DP chip, anything over 6 and it'll blow black smoke.
    think the majority only increase fuel despite the sales pitch.
    Mine it set on 5 no smoke heaps more poke, so I just leave it on 5 for towing as well
    I also have full straight through 3" zorst
  6. #6
    Jul 2012
    Hobart Tasmania
    The Chip is different to the DP chip as is does not plug into the rail but individual injectors. From the litriture, it says that the normal position is %20 extra power ect, then the dial just fine tunes to suit car characteristics, little more little less, but thats it. LOL.
  7. #7
    Jul 2012
    Hobart Tasmania
    Ok Well did some testing with my mate and holy shit what a difference. Mine has exhaust and snorkle no chip, his has stock intake stock exhaust and a chip and the 0-100 time was 5 seconds slower for me, the dam things goes like its got after burners, incredible. The car simply pulls like a freight train, top end power is imply amazing compared to stock, would like to see what this thing will be like with an exhaust too.
    I WANT ONE, only problem is mine is under warranty and as such i don;t want to do anythign to void it......HUMMMM....
    ALSO, if you set the knob to max, it goes a bit better but drinks fuel in gallons, stock setting looks to be just fine.
  8. #8
    ACT
    Good stuff mate, glad you guys got it sorted.
    Any economy reports yet? Also you say top end power increase, what about bottom end? I feel thats where the 3l lack but a good exhaust seems to help that low end a lot.
  9. #9
    Jul 2012
    Hobart Tasmania
    Yeah i just wish i could install one in my car without Mr Nissan having a hissy fit.
    The bottom end is not as good as mine, well not as linear, there seams to be a big lung at about 1800 rpm, where as mine starts pulling at about 1500-1600 rpm but i have an exhaust. Mine is starting to taper off at 3500 where as his pulls all the way to 4K or there about.
    In terms of Economy can't tell as he never kept logs priot to the chip, but once he ha s a few tanks under him i will see what Km he gets out of the tanks.
    I manage abut 900km out of 115L and i have full logs of mine so i can compare against his.
    BUT at full max setting you can almost see the needle move every time you step on the go pedal. LOL.
  10. The Following User Says Thank You to WogsRus For This Useful Post:
    Maxhead (14th January 2013)
  11. #10
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    I have a Diesel Smart module / Chip whitch works on the same principle as the Stein. They adjust injector timing not fuel rail or pump presure. The plus 20% is for straight stock standard engine no mods. If your mate tows a heavy caravan or something like that dialit up a little. BE carefull of turbo over boosting.
    Steve
  12. The Following User Says Thank You to Steve4wdin For This Useful Post:
    WogsRus (14th January 2013)
