Results 1 to 10 of 15
Thread: Clutch booster Rebuild
    Advanced KL570's Avatar
    Jul 2012
    alright guys here's the rebuild I did on my clutch booster. cost me less than 100 and works as good as new!
    step 1:
    remove everything off front of booster and undo everything inside the firewall that is connected to the booster. should be 4 nuts holding it in place.
    here's what you get:
    1 stuffed booster
    step 2: put booster into vice and clamp it with the 4 studs Inside and the main shaft pointing DOWN. don't squeeze the crap out of it, just enough to hold it in place and not move.
    here's the fun part...
    step 3: get a piece of square bar about 400-500mm long. drill 2 holes in it to slip over 2 diagonal opposing studs, make sure you've removed the little rubber seal and washer with a screwdriver and remove the shaft that goes into the master cylinder.
    now use it as a massive breaker bar ad PUSH!!! will take a bit of muscle!! you need to rotate the top half until the little gaps line up and you can seperate the 2. THE 2 HALVES ARE SPRING LOADED. TAKE CARE SEPERATING!
    here's what you get
    pretty much, from here just replace all the corresponding parts.
    make sure everything is clean before you out it back together, and paint the outside if you wish!
    here's some more pics if they help!
    and finished!!
    any questions feel free to ask! I'll try an remember what I did haha
    cheers,
    Kade
  2. The Following 15 Users Say Thank You to KL570 For This Useful Post:
    amm009uk (13th June 2014), Bloodyaussie (2nd July 2014), Bob (18th December 2012), dom14 (18th August 2016), gazman63 (15th February 2023), GQSWB4.2 (17th November 2014), jedediah (4th March 2015), mudnut (2nd July 2014), MudRunnerTD (18th December 2012), nissannewby (18th December 2012), Robo (21st December 2012), spektrum (18th December 2012), Teeny (13th May 2013), timmay556 (23rd June 2014), weinie (20th June 2017)
    Jul 2012
    oh and this is the rebuild kit I used:
    http://www.atocauto.com.au/proddetai...od=30684_01J25
    2 day delivery time!
    cheers,
    Kade
  4. The Following 3 Users Say Thank You to KL570 For This Useful Post:
    mudski (18th December 2012), Robo (21st December 2012), Teeny (1st July 2013)
    334 Post(s)
    Outstanding work there bloke. I probably would have just chased a second hand one but your the man!! Nice one!
    Would the Brake Booster be the same task? must be very similar?
    Jul 2012
    cheers mate!
    yeah I got quoted 250, reasonable, but I was a poor student at the time Nd I freakin love doing stuff myself. learn more about stuff and how to properly diagnose problems this way
    brake booster is exactly the same! just a bigger diaphragm really!
    334 Post(s)
    Quote Originally Posted by KL570 View Post
    cheers,
    Kade
    Great Store too mate! Nice find!
    Jul 2012
    thanks mate! was actually recommended by someone on this forum ages ago!
  9. #7
    Advanced spektrum's Avatar
    Good job.
    My clutch booster has completely stopped working now. The brake booster is intermittent too, although could just be a lack of vacuum from the clutch booster leaks.
    1992 Patrol GQ LWB TD42
  10. #8
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Great write up Kade and pics to match.
    Very understandable for a DIY.
    Great work mate, cheers
    TAP TAP TAP MERRY XMAS TO ALL AND A SAFE NEW YEAR TO COME
    "Tonka Tuff" 08-GU6, 3.0lt crd, 5 Speed, Turbo Diesel, Hpd, Arb, Ome, MT Baja Atz.
  11. #9
    Jul 2012
    Quote Originally Posted by spektrum View Post
    Good job.
    if they're both not working and you're not losing fluid I'd be checking your vacuum pressure man. probs a leak somewhere!
  12. #10
    Jul 2012
    Quote Originally Posted by wild98 View Post
    cheers bud
