Hi guys more dramas, changed the battery and everything works but the car won't crank over??
I have checked some of the fuses but they look ok.
wont turn over at all?
you have dash lights?
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
Get too small a battery maybe
Such is the rule of honour.
just had a look at the specs and it is only 675 cca where as the n70zz is 720cca
so i would agree with macca86 swap the batteries you have over so the auxilery is used as the main starter (thats the ones in the battery trays)
or link them togeather as you can do with the redark isolator 0r jumper leads
hope this makes sence
OH LEATHER IS NICE
mine is a 710cca so should be ok and i spoke to the guys at cat and thats the one they sell for patrols, everything works but it wont crank at all??
from memory you need the N70ZZL as the N70ZZ has a reverse polarity so check you have the correct polarity. fingers crossed im wrong
Think you're right mega, mine was like that.
DIAL-A-TAP
I checked when i put it in, the polarity is correct, I have power to everything it just does nothing when i turn the key to start, glow light goes out has lights stereo but wont crank at all, when i get home i will take the battery connections again and make sure the little relay contacts are clean and getting a good contact, cant be much else.
There is a fuse from memory its 35amp red one that sits next to the battery in that black plastic case, which should be labelled starter, just double check it and make sure it hasn't blown. Mine being a safari it's 24v so could be different on a 12v.
Stropp (1st December 2012)
I dont know anything about patrol security but could your keys need reprograming?
