Hi Guys. just wondering if you can put Gu ti rear diff centre into the front diff centre, if not why not, regards Alex
p.s. I have 97 GU Ti with eletric rear locking diff centre
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
No you cant. Spline counts are different on the axles. And also the actual size of the diff if its a H260. What are you wanting to do?
I trying to go with a nissan electric diff locker that in the rear of the GU Ti model and putting one in front . but it the Spline count is different , can you get front axles to suit or is it easy to go with a air locker regards Alex
Easier and cheaper to grab an aftermarket locker. You can go air, electric or auto
altech (19th November 2012)
A couple of my mates have detroit auto lockers and they work well two front wheels always spin when they are on the power and will also let them turn when they are not on the right peddle,
altech (23rd November 2012)
