Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Pertronix Problem
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Pertronix Problem
    Ive just fitted a pertronix ignitor2 electronic ignition module paired with the flamethrower2 coil.
    On start up it idles fine but as the engine warms up it starts missing. The hotter the engine gets, the worse it misses. Leave it overnight and start again and it runs perfect till it starts warming up.
    I fitted new leads and plugs. Ive triple checked the wiring and fitting instructions. None of the wiring heats up (as in shorting out).
    A mate fitted the exact same kit to his maverick and it works fine.
    Any ideas to what is wrong? Could the module be faulty?
    My brother mentioned that in other cars they put a bit of heat proof grease under the module to stop it heating up too much but the pertronix kit doesnt mention anything about it and my mates runs fine without it.
    On the good side, even missing and carrying on like it is its already using less fuel and has more power
    Hello from Under Down Under!
    22 Post(s)
    to me it still sounds like a wiring issue I know you have checked it but how do you check looking or continuity checks? I would get the meter out and check continuity you may have a dodgy termination
    96 GQ coil/Cab
    08 G6eT
    Aug 2011
    North West Tas
    56 Post(s)
    Havent checked the continuity. Car was running fine before i fitted the ignitor and there are only two new wires that come from the module that go to positive and negative of the coil. What do you mean by dodgy termination? should i just check the continuity of all the wiring?
    22 Post(s)
    there would be lugs or crimps on the cable? they might not have been crimped correctly. yes I would check all for continuity, if they are all good it could be a faulty module
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    taslucas (5th November 2012)
    Aug 2011
    North West Tas
    56 Post(s)
    the instructions say to by-pass the balast resistor. I bypassed it and joined the wires but i didnt solder them. Could that be a problem?
    22 Post(s)
    how did you join them??
    96 GQ coil/Cab
    08 G6eT
  8. #7
    Aug 2011
    North West Tas
    56 Post(s)
    I joined them like this. I thought that it would be as good as the original join onto the ballast resistor.
  9. #8
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Sounds like a component breaking down as it heats up. Could be a faulty module.
  10. #9
    Aug 2011
    North West Tas
    56 Post(s)
    I have been in contact with the seller. He has sent me some PDF instructions about how to test the module and the coil. He also suggested that it sounds like the coil was faulty and to fit my old coil and see if the problem goes away. Ive just refitted my old coil and ballast resistor (lucky i didnt solder the wires together) and will test it out tomorrow.
  11. #10
    Aug 2011
    North West Tas
    56 Post(s)
    I put my old coil back in (and ballast resistor) and drove to work this morning. No change. As the engine warms up, it starts missing. The hotter it gets, the worse it misses. So I've got original coil and ballast resistor, brand new leads and plugs. It must be the module then ?
