Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: h.i.d 's make my stereo crackle!!!!
  1. #21
    Advanced Boofa's Avatar
    Na, no C-Tick logo that I can see on my LED light bar, mabey this is an issue with cheaper gear.
  2. #22
    You'd be surprised how much trouble this can cause, I'll stand by it
  3. #23
    Bumped, has anyone got an update yet?????
  4. #24
    Hardcore
    central coast nsw
    Na sorry, been to busy at work.
    Will go over lights and aerial.
    Get to it 1day soon I hope.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  5. #25
    What is it actually called an Antenna or an aerial???
    or are they they same? maybe small technical difference.
  6. #26
    Expert mick.'s Avatar
    Newcastle (NSW)
    I've asked this question before.
    Apparently the only difference is the Americans call it an antenna and the British call it an aerial.
    Cheers Mick.
  7. #27
    Hardcore
    central coast nsw
    Macquarie dic.
    short version.
    aerial is --- radio reception / transmission.
    antenna is 1st meaning --- belong to an insect/ crustaceans etc.
    antenna 2nd meaning ---- radio or tv aerial.
    so 1 and the same !.
  8. #28
    Expert russ81's Avatar
    GOSNELLS WA
    Believe it or not the technical difference between the 2 is
    Aerial= receives only ie tv
    Antennae = receives and transmits ie UHF
    Sent while be temporally motionless
  9. The Following User Says Thank You to russ81 For This Useful Post:
    threedogs (25th September 2012)
