Results 1 to 3 of 3
Thread: Someone with a nads setup in nsw near sydney?
    Patrol Guru Morton's Avatar
    Sydney West
    Hi all, after some issues with my 02 3L GU I have decided I had better sort this out, I am losing power under exceleration periodically, usually 3rd or 4th gear, It blows severe white smoke on startup when it finally fires up, sucking the fuel down badly, less power, flat spots. At this stage I am up for new glows plugs apparently & the intercooler is leaking.
    Having said that I need help in areas, someone that sells a decent rebuilt intercooler that comes recommended, secondly someone in Sydney that has done the NADS work completely that I may be able to meet up with or they can stop by at my joint in Sydneys west, am happy to drive up or down the coast or west an hr or 2 to meetup, I would like to look at the setup that is done so I can get my head around it, I will need guidance on this job, thirdly someone than can sell me the gear to do the job, is there a one-stop shop, do I look on fleabay?
    Help please
    Maroochydore, SunShine Coast.
    Check out A.R.E. for intercooler, they have 2 different ones, first is an upgrade, 2nd is a modified if you are doing engine mods eg: exhaust etc
    Drive is 04 DX wagon, 165Ks, Dual Batts, 12000kg Warn in steel bar, Snorkel, Xray 220 Hid Spots, Cruise, digital EGT, Draws in back with power box, 40Ltr Waeco for the essentuals
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    i live near gosford if your willing to travel there, i have the nads fitted and did it all myself so may be able to give some advice/ tips if interested send me a personal message with your number and we'll go from there cheers....
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
  4. The Following User Says Thank You to grimace For This Useful Post:
    Morton (31st August 2012)
