Results 1 to 5 of 5
Thread: size of hoses for provent
    Patrol God Stropp's Avatar
    38 Post(s)
    hi guys just need to know the size of the hose for the provent fitup, can remember 1/2 and 5/8 somewhere is that right, just want to get mine on this weekend. cheers stropp
    btw for a 4.2 td gu
    Nov 2011
    Townsville
    The pro vent is 3/4 and 1/2 from my memory yoy could check their website it has all the sizes you will need to reduce it down for the patrol
  3. The Following User Says Thank You to Killametre For This Useful Post:
    Stropp (7th August 2012)
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    I'm in the process of fitting mine.(assuming its a Provent 200) I've got all the hoses made up and ready to go, I just need to find the time to install now. The hosetails for the inlet and outlet off the actual catch can is 1", so you will need to reduce that down to 5/8" to fit on the breather and turbo inlet pipe, and the oil return/drain line is 1/2".
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
    38 Post(s)
    Thanks mate, i have ordered the stepped barb 25mm(1") to 16mm(5/8) and will get the hose and clamps and tap to suit. Cheers Stropp
    I looked at using a stepped barb but couldn't justify the price. I went to the local plumbing shop, not Bunnings, and got a copper reduce piper for both sizes. Actually it was two 1inch to 5/8 reducers, but then I put a small length of 1/2inch copper pipe inside the 5/8 end of one to make it 1/2. Cost me about $10 for both.
