Results 1 to 10 of 12
Thread: body lift for gq wagon
    hey guys thinking of putting a 2 inch body lift on my gq wagon it has a 2 inch sring lift already was wondering if there would be anything i would have to change after the body lift its an auto trans.
    cheers
    Be interested to know myself considering doing the same.
    I think i read something about extended brake lines.
    Expert mick.'s Avatar
    Newcastle (NSW)
    It's been a while since I've done one but I think this pretty much sums it up. To do it properly you need to drop the radiator 2inches (dodgy way remove bottom of shroud), bend high/ low range lever with oxy (dodgy way cut floor), lengthen your fuel filler hose, lengthen hose or modify bracket for brake vacuum, stretch your copper brake lines on the firewall and to make everything looks right you need to modify your, side steps, bullbar and rear bar by lifting them 2 inches to suit.
    Cheers Mick.
    ok cool thanks mick i no bout the bullbar sidesteps and rear bar and brake lines but not the other stuff thanks again.
    and how do u no if the shocks are ajustable i got told that they were ajustable when i bought the car but not sure how to tell.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by 41ook_patrol View Post
    the shock will have some type of knob on it to allow you to chance the setting.
    cheers
    Todd
  6. #6
    Newcastle (NSW)
    Depending what type of shocks you have on how there adjusted. Tough Dogs, Ranchos and Boss have a knob on the bottom of the shock which you turn clock wise to stiffen them up. Koni's need to be removed and twisted I think.
    Cheers Mick.
  7. #7
    sweet thanks guys ill have a look today i got told they go out to 3inch full so yer will have a look.
  8. #8
    Aug 2010
    17 Post(s)
    That will have nothing to do with been adjustable, If you are unsure on what adjustable shocks do, just ask for more explanation.
    Todd
  9. #9
    Newcastle (NSW)
    I think you may have air shocks which pump up with compressed air. You will find a valve somewhere where you stiffen them up for carrying heavy loads or towing.
    Cheers Mick.
  10. #10
    Aug 2010
    17 Post(s)
    Can you upload a photo of the shocks? It would help with letting you know what type of shock they are.
    Todd
