Results 1 to 4 of 4
Thread: td4.2 non turbo upgrade to turbo etc
    Oct 2010
    Unhappy td4.2 non turbo upgrade to turbo etc
    Hi all been an hour reading all, well some of the forum, great info, thanks. My question is I want to upgrade my gq. I was looking at extractors and 3" exhaust, but also interested in putting a turbo on her. If I put extractors etc on are they different for non turbo and turbo, or should I turbo first (this will take some to save dollars. thanks for any info I can get..cheers
    Expert beansathome's Avatar
    Nov 2010
    deception bay (QLD)
    Quote Originally Posted by grumpy mongrel View Post
    hello grump mongerl
    im not sure if u no to much about how turbos work but u need a mounting position on your exaust manafauld for the turbo.if i was u i would be looking at doing the extrackters and turbo at the same time. and are u looking at a press bent or mandrell bent exhaust ?
    cheers ben
    An extractor exhaust system will cost about $1000 installed and increase power by about 10%. I wouldn't go any bigger than 2 1/2" on an otherwise standard engine and mandrel bent pipes are better than press bent pipes.
    A basic turbo set up will cost at least $4000 fitted and tuned, and to get the most benefit from the turbo you will need a decent exhaust, 3" mandrel bent is good. A basic turbo with matching exhaust and all tuned will increase power by about 30%.
    The extractors fitted to naturally aspirated engines are not suitable for fitting turbo's. Unless you plan to take your Turbo Patrol racing a properly designed log manifold (that comes with turbo kits) is all you need.
    Tony
    Oct 2010
    Hi guys thanks for that, it has solved my problem. I know nothing about turbo, or really mechanics so that info is what I wanted. Thank you beansathome and ynot for info. Guess have to keep on saving my dollars.cheers
