Results 1 to 10 of 16
Thread: How to tie down a patrol on a trailer
    Dwellingup, WA
    Lightbulb How to tie down a patrol on a trailer
    Could someone with expertise in this area please provide some facts on correct/safe tie down procedures that should be applied to loading, securing, towing and unloading a patrol on a trailer (flatbed or car trailer) and probably some things one should NOT do...
    I am about to pick up my stationary patrol wagon and have learned a few things from various googled sites but we need it all in one place, perhaps in the 4x4 safety forum? Thanks guys.
    Are you ready for Christmas?
    Sep 2011
    adelaide
    18 Post(s)
    G`day mate.
    Most professionals strap over the wheel that's so the suspension movement does not come in to play
    Remember you have roughly two and a halve tons car so balance is to be considered especially on a trailer.
    Normally tie either the back or front down by using the axle as the tie down then at the other end preferably using a 3 ton ratchet strap over the axle again pull up as tight as possible then pull the hand brake on and if you want place in gear If you have a winch mounted on the trailer tie off opposite end then winch up firm and tie off the winch end.If possible don't use the tie down points on the body. Hope this is of some help.
  3. The Following 2 Users Say Thank You to pearcey For This Useful Post:
    growler2058 (2nd January 2012), Oversize (5th January 2012)
    May 2011
    mackay former alice boy
    If your using rope halve the rope and create a loop and drop over the tyre but above the disks .take 1 end and secure around a upright under the top rail and tie off with a clove hitch to the centre of the vehicle then tension the other end with a truckies hitch or sometimes called a purchase knot under the top rail. If using tie down strapes use the same method but keep slipping the half loop to take up the slack then tension to the front and rear.also its a good policy to use the vehicle tie down points or bullbar and tow bar to run retainers to the mid point under the vehicle these need to be hitched off the vehicle so if one end cuts through the other side will keep it steady;(allow for suspension to work) pearcy has a very valid point balance the vehicle so that the combo sits even so you'll probably not have the steers right against the front rail. If you need any more help reply and well get on the phone.
  5. The Following User Says Thank You to dads tractor For This Useful Post:
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    if putting ropes or straps over the diff housings, watch out you don't squash the brake lines.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  7. The Following User Says Thank You to Silver For This Useful Post:
  8. #5
    Patrol Freak fixer982's Avatar
    May 2011
    Adelaide, SA (The state of confusion).
    Quote Originally Posted by dads tractor View Post
    Is anyone else as confused as me. I am sure you are right, Dads, but I wouldn't have a clue how to do what I think you just said. I would just use lots of ratchet tie downs, make sure they don't rub on sharp bits and check it often while travelling. The balance point is important though. I once loaded a Charger onto a car trailer backwards, but it took only a couple of Kms before we took it off and turned it around. Nose heavy is best for a trailer.
    GU Series 4 Ti, 3.0 CRD Auto with extra bits
  9. #6
    May 2011
    Quote Originally Posted by fixer982 View Post
    Yeh its a bit hard to explain maybe I could put together a series of videos on tying off loads and knots to use etc
  10. The Following User Says Thank You to dads tractor For This Useful Post:
    AB (4th January 2012)
  11. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    One very important thing (that sounds simple) is to always put the vehicle on forwards (facing the same way as the tow vehicle). Unless its a rear engined vehicle. Never put the engine to the rear as the weight distribution is too far back and takes the weight off the tow vehicles rear wheels which makes bad things happen!! My mate wrote off the tow car on the highway doing this.
    Edit: Sorry fixer just realised you had already said this
    Hello from Under Down Under!
  12. The Following User Says Thank You to taslucas For This Useful Post:
  13. #8
    Dwellingup, WA
    mmm, soooo many people have told me this one, can't imagine how many people have actually done it and learned the hard way.
    Quote Originally Posted by Silver View Post
  14. #9
    Dwellingup, WA
    I have a vague idea what he is saying, seems to have a method of stabilising some of the bounce and adding more tie down points at the same time. Thanks Dad
  15. #10
    Dwellingup, WA
    Thanks guys, this is great. Much appreciated.
