Page 23 of 67 FirstFirst ... 2122232425 ... LastLast
Results 221 to 230 of 664
Thread: Merged - Deleted "Other - Cars, Bikes & Parts."
  1. #221
    Good to see you back mate, I will change that now.
  2. #222
    Oct 2011
    CB Radio's
    G'day guys,
    I've previously looked into getting a CB Radio, I installed one I was given however it doesn't seem to work :/.
    My question is. What do I need to know when looking for a CB, I have looked for prices and been hit with 100 questions that I have no idea on. Any help would be appreciated.
  3. #223
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Unfortunately questions will come to figure out what you need.
    So,Are you looking for UHF, VHF,HF or 27MHz CB?
    Most would use the UHF radios these days so probably a better option.
    What do you want to do with the radio..ie: communicate in a convoy, talk to people over mountains or long range communication or even just for emergency?
    Let us know what you need it for and we should be able to give you some more accurate answers.
    ________________________
    ______ 2017 D-Max _______
  4. #224
    Oct 2011
    Thanks for the quick reply!
    In the long run, communicate with convoys, however currently my friends that come out with me are only talking about joining the dark side, so its best use will be in case of emergency.
  5. #225
    Oct 2011
    Oh And what are the operating differences between high, very high and ultra high?
  6. #226
    ACT
    The operating of these radios are very similar but you would need a licence for HF and VHF( pretty sure) and there are different protocols of using these
    You need to find out what your friends are using so you can get a same radio to talk to them
  7. #227
    Oct 2011
    Where do these fit around usage? as in if I went UHF, so no license, That would be ok for convoy and emergency?
  8. #228
    ACT
    Quote Originally Posted by yakumo View Post
    Certainly would be, most people use a UHF. The reason I was asking the question of what you would use it for is so I could recommend and aerial at the same time.
    For example, you need a UHF for talking to your mates in a convoy. I would recommend a basic UHF and an 3db gain aerial(good for short distance comms)
    If you need a good allrounder aerial I would recommend something around 6db. 9db for long distance.
    Radios vary in quality and price, I use a GME which is Aussie made and very good quality. Others will have different opinions.
    I think I posted a picture of which aerial performs better in different terrains....I'll find it for you shortly..
  9. #229
    ACT
    Check this out as well for some info mate:
    http://www.nissanpatrol.com.au/forum...ight=frequency
  10. The Following User Says Thank You to Maxhead For This Useful Post:
    yakumo (18th October 2011)
  11. #230
    Oct 2011
    So, Im generally going to be on a beach, which is actually fairly bumpy, and curves around dunes, most will be in a convoy, however if supplies are needed It would be good to have contact for as long as possible, What antenna would you recommend?
