Results 1 to 8 of 8
Thread: GQ aircon LED upgrade
    Expert lachiek's Avatar
    Sydney CBD (for my sins)
    Hey all, anyone who has had the stupid little green bulbs behind their aircon unit blow knows what a pain it is and Nissan wants $40 per bulb for these so I did a LED replacement which is permanent and easy to do. Pics are only of job done and the circuit if you want to copy. Cost about $12 all up and took 30 mins if you know what you are doing with a solder iron.
    Haven't plugged it back into the car yet so will post lit photo's later.
    The unit - mine is climate control from a Safari but the bulbs are the same as on a normal aircon model from an Aussie spec Patrol.
    Original bulb
    Circuit
    Circuit board - you can see the back of the LEDs soldered into the board (red circle) and the 1/4 watt resistors used to drop down the cars 12 volts to the LEDs 3 volts.
    Power input - A few copper tracks on the circuit board blew from trying different types of bulb. The coloured wires are replacing the busted tracks.
    The LED pokes through the board into the light tube.
    The LEDs are a lot brighter than the original bulbs and a bit more directional so there are some bright spots on the display but overall I'm really happy and this system should now outlive the rest of the truck.
    GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
  2. The Following User Says Thank You to lachiek For This Useful Post:
    MudRunnerTD (23rd May 2012)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by lachiek View Post
    Original bulb
    Circuit
    Nice tip mate - if I tried that, it would all be over for Tank!!! I'd fry something for sure!!! lmao
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Well done mate, thanks for posting it up here...
    Feb 2012
    Going to improve the look of my interior a little more! little things like this make a HUGE difference. Cheers mate!
    Feb 2012
    A light sand on tip of the LED with some coarse sandpaper should help diffuse the bright spots.
  7. The Following 2 Users Say Thank You to axl For This Useful Post:
    MudRunnerTD (23rd May 2012), Robo (7th March 2012)
    Feb 2012
    Awesome job mate great idea
  9. #7
    Bexley, NSW
    great job mate...
  10. #8
    The original bulbs are ridiculously priced genuine for any car.
    I Struggled to find the little replacement bulbs anywhere locally ended up finding them at wes components.
    http://wagner.net.au/
    Was about $2 for a pack of 10 from what i can recall.
