24th March 2012, 04:38 PM
Advanced
uhf ariel trrough fire wall
I am trying to get the ariel coax cable from the engine bay through the fire wall into the cab, on a 2008 gu 3.0 td , are there any spare holes that any body knows of? how do others do this? i was trying to avoid cutting through the side of existing cable glands. or is this the only way to do it?
24th March 2012 04:38 PM
24th March 2012, 05:26 PM
Moderator
Straight through the middle of said gland or there should be more than a couple of bungs in the fire wall. Take your pick but just straight through the bung mate.
Check out my Toy -->
Rogue Dung Beetle
24th March 2012, 05:28 PM
Yes there is a hole straight into your cab,
run the cable along the passengerside of the engine bay, and right infront of the passenger glove compartment, down lowwer.... on the firewall,
you will see a very large grommett, size of about 6 cm oval, and its black.
Pull it out, and slide the coax in there, then put grommett back in.
Make sure the cable isnt tight as it passes through the firwall/grommet sanwich
And you will have a very nice seal, once you put grommett back
it pops through, just under the dash, just above the highest point of the carpet, on the passenger side..
Like right behind the glove box.
good luck !
24th March 2012, 11:59 PM
Advanced
4th April 2012, 11:59 PM
Advanced
Uesful thanks will do the same for a nextg antenna
