25th February 2012, 10:33 AM
AC - sensor on GU patrol
Hi Guys, on hot days ,I found that while in traffic my Air-con cuts out because when the Temp needle go over half way mark on gauge. then when it drops below half way the Air-con goes back to normal and keeps driver happy again LOL. ? because Temp never goes to 3/4 on temp gauge, can you over ride the AC sensor by putting in a cut switch to it and the other ? is where is the sensor located , regards Alex
25th February 2012 10:33 AM
25th February 2012, 09:13 PM
I don't know what engine you have, but if the A/C is cutting out due to excessive heat then you have a problem with your cooling system.
I would make sure there is no blockage between the condenser and radiator and that your cooling system and fans are working correctly.
The Following User Says Thank You to Yendor For This Useful Post:
altech (26th February 2012)
26th February 2012, 08:38 AM
Hi Yendor, Yep water level fine, fan is working , air - con works good too, temp gauge just below half , don't no if this is normal for a GU patrol 4.5 Ti , but only on hot days and in stop,start traffic regards Alex
26th February 2012, 09:57 AM
The other reason why your A/C is cutting out could be because the gas pressures inside the A/C system are getting to high.
Once again this could be because of poor airflow through the condenser and radiator, your A/C has to much gas in it or you have a problem within the A/C system.
So if your cooling system is working correctly I recommend you take it to a auto A/C mob and get them to inspect and service your A/C system.
Sorry, I don't feel comfortable telling you how to bypass this safety feature, it would be like me telling you to bypass a fuse that keeps blowing with standard wire.
26th February 2012, 10:43 AM
Banned
Sounds a bit like the thermo switch at the evaporator could be playing up also (whether mechanical or electrical) - either way, as Rod suggested, time for an AC specialist to have a gander - hope its not that thermo switch though, they aren't cheap ...
Good luck with it mate - hopefully something simple. I spent 5 hours going over my AC system on Friday due to it not working, and after pulling everything apart, buying a new $56 relay, and fearing the worst, it ended up being the power line between the relay and the pressure switch!! $1 in materials and 3 minutes later it was fixed!!! lmao ... always the way when I tinker with electrics though!! lol
The Following User Says Thank You to Bigrig For This Useful Post:
