31st August 2010, 01:26 PM
gq 3l having trouble bleeding clutch.
i just replaced a leaking clutch master cylinder with a new one and im having trouble getting pressure in the system
wat do i do?
31st August 2010 01:26 PM
31st August 2010, 06:37 PM
there are 2 bleed points on GQ's, if you follow the line you will find one up top. Star at that one & then go down to the bleeder on the slave.
This should see you right.
If not post back & I'll see if I can help feather.
Paul
11th March 2011, 08:14 PM
11th March 2011, 11:16 PM
There is a way to bleed 1 man style.
You will need to make a lid with an air fitting in it for the clutch fluid resevior, then hook an air line to it, set at only 5psi at max on your regulator, place heavy object on pedal to depress it. now crack and bleed nipples at will.
Tim
The Following User Says Thank You to Finly Owner For This Useful Post:
growler2058 (12th March 2011)
12th March 2011, 08:27 AM
SPAMINATOR
Finly Owner
Tim
Ahh a thinking mans man i like it
12th March 2011, 09:31 AM
When fitting any master cylinder, clutch or brake, you shoud bench bleed the cylinder first, I have never had a problem when doing this first
25th February 2012, 06:33 PM
patch697
Paul
i have looked and can only fined one. you have the line from the master then goes to a join then to the slave
25th February 2012, 06:41 PM
My td42 has 3 bleed nipples the rd28 did as well.
I used a vaccum bleeder even then i got a pedal but wasn't perfect until drove around for a while and left it over night then it came good.
25th February 2012, 06:48 PM
bleeding cluch
i have bleed the cluch twice now and go's well then all of a sudden carn't get it in gear. dont know what i'm doing wrong
25th February 2012, 06:53 PM
If you pump it up a few times does it go into gear ok mine was like that until i drvove around a bit then left it sit over night then like i said came good on it's own
