26th September 2011, 03:00 PM
GQ Air con
The conpressor is not getting power, does anyone have an idea where to start looking. Fuses and the relay near the battery is ok.
26th September 2011 03:00 PM
26th September 2011, 03:29 PM
Have you tried hot wiring the pump clutch to make sure its working?
On the receiver dryer there is 2x pressure switches & if your system has not got enough pressure the aircon will not engage.
This the first place I'd be looking if your fuses & relays are in good order.
This is one of those process of elimination jobs so start with the simple stuff first & work your way through it.
