21st September 2011, 09:55 AM
Tacho Pulse frequency on 2.8td Y61
Hi all
Does anyone know the tacho pulse frequency on 2.8td. I am trying to connect a GM tacho pulse to the nissan tacho. I have tried to connect it together and the tachometer goes straight to 5000rpm.
Thinks
Kris
21st September 2011 09:55 AM
21st September 2011, 10:37 AM
Get in contact with this mob: http://www.nissanpatrol.com.au/forum...s-4wd-Adaptors
They have a range of interface units to integrate the factory taco in with a retro fitted engine at around the $160ish mark, other then that its an after market taco.
22nd September 2011, 03:34 AM
Hi Patch
Thinks for a quick reply. I conntaced Mark and unfortuntely they didnt have any thing for me and didnt know the frequency. So my search continues
The Following User Says Thank You to kristjanb For This Useful Post:
patch697 (22nd September 2011)
22nd September 2011, 09:56 AM
kristjanb
Hi Patch
You may need to find another taco to suit your model in a petrol mate & go from there if you want to keep it factory.
The Following User Says Thank You to patch697 For This Useful Post:
kristjanb (22nd September 2011)
22nd September 2011, 10:31 AM
Mark talked about that as well. I have found a shop here back home that can make for me a frequency converter and he has done it before for patrol but he cant remember the pulse frequency for the 2.8td, if I can get somewhere the pulse freq which the 2.8td runs then I am good. Problem is as well I dont know anyone that owns a 2.8 patrol which would be good then I would just borrow it and measure the frequency.
22nd September 2011, 12:24 PM
Have you tried a 1/2 watt veritable resistor (trim pot) to trim the taco? (Ive done this on past units)
Something like this.
Image is a tad small but you get the idea
kristjanb (24th September 2011)
24th September 2011, 09:38 AM
No I havent tried that. This is good idea to try out. Thinks for this Patch
12th April 2012, 09:16 PM
I don't know if this will help you, but a td42 produces 30hz @ 600 rpm, 60hz @ 1200 rpm and 90hz @ 1800 rpm.
I am looking at building a frequency converter to interface a td42 with a zd30 tacho so I got the oscilloscope out the other day. seeing that the td42 sensor works ok with a rd28 tacho I an guessing the cycles are the same.
13th April 2012, 07:19 PM
By GM do you mean General Motors?
Is the tacho signal coming from an ECU?
The resistor can reduce the voltage, but it won't change the frequency, and you may need to do both.
Have a look at Dakota Digital http://www.dakotadigital.com/index.c...cat/cat287.htm
