Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Downhill descents with AUTO's
    Expert Mazodude's Avatar
    Aug 2011
    Forest Lake, QLD
    Its those trees that arnt big enough to damage you vehicle but are big enough to slow you down.... or an import if your in the city. the beauty of imports is that they can be used as a wheel chock or a ramp
    I have wanted to to that for soooo long
    I think something is wrong with me.
    ontopic: don't have a auto, but my mate does. stick it in low range, 1st gear. Much slower.
    "Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
    Will have to try this as my gq flys down hills in low first and im always on the brakes
  4. #13
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Works well indeed, used to use the handbrake in the bt50 in muddy uphill climbs and it gradually crawled up no issues.
    Did the same in the patrol awhile back but the old " kirup syrup" mud down south ended up getting the better of the old AT's and bogged
    Tap, Tap Taparoo
    www.swat4x4.com
  5. #14
    Aug 2010
    Lower Blue Mountains
    16 Post(s)
    Sniko,
    Have moved your thread fron General into the Gearbox section and also made it a sticky
    Toddie
  6. #15
    Western suburbs of Melbourne
    7 Post(s)
    Great write up Bel, will have to try to remember what I learnt. Thank.
    Publicly speaking to a private audience.
  7. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    owenoldfella (28th September 2017)
  8. #16
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    I've used it previously, works well.
    It probably does heat up your ATF a bit but maybe you just need to flush it a bit more regularly.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
