7th September 2011, 05:35 PM
7th September 2011 05:35 PM
7th September 2011, 05:52 PM
Before you go doing that growlers try some rebuild in a bottle..... (Power steering stop leak & conditioner)
If Aggy has been sitting for a bit she may just need some softening up & its sh!t loads cheaper if it works & no great loss to your hip pocket if it don't.
The Following User Says Thank You to patch697 For This Useful Post:
growler2058 (7th September 2011)
7th September 2011, 05:57 PM
patch697
The only fall back Ive had doing this in the past is the increase in pressure can sometimes create a leak in a power steering hose but if it does (as in one case of mine) the lines are on the verge of going anyway & better to find out before your off road & miles from anywhere.
7th September 2011, 07:08 PM
SPAMINATOR
patch697
Cheers mate i'll give it a crack
7th September 2011, 07:10 PM
SPAMINATOR
patch697
Whats the brand name mate does supa cheap or auto pro do this stuff
20th September 2011, 06:46 PM
I have re sealed these boxes before the seal kit is about $150 You have to be careful when putting the ball bearings back in in as they are different sizes, although they look the same. It isnt a difficult box to to work on otherwise, no special tools needed.
20th September 2011, 06:50 PM
SPAMINATOR
pbdarwinnt
Beauty cheers mate
6th October 2011, 10:39 PM
Advanced
what happens if you put the ball bearings back in the wrong order.
also, i've recantly pulled my stearing box apart and put it back together and the turning circle isn't as good what would cause this?
7th October 2011, 12:19 AM
Banned
dirty_dog
Turning circle worse both ways?? If only worse one way, then it's off centre and will need to be re-centred.
7th October 2011, 01:17 AM
RIP - valued member and true gentleman of this forum that will be missed by many!
Lucas power steering stop leaky kinda stuff was recommended to me by the GQ driving mechanic over the road. It is thick like honey, and seems to be working on Silver's
The Following User Says Thank You to Silver For This Useful Post:
growler2058 (7th October 2011)
