Results 1 to 3 of 3
Thread: Gu patrol zd30di power problem
    Jul 2024
    Hi guys I have a 2001 gu zd30di I’m having a problem where I can be driving along and then I have like a power cut then if I take my foot of the Excelerator and back on power comes back for 7second then happens again and so on it also will only make 10psi of boost and if I try turn the daws valve up it won’t make and more boost tried searching everything can’t find anything on the problem any info would help a lot thanks
  2. #2
    Dec 2024
    Did you ever find the issue Jayden
  3. #3
    Dec 2024
    Did you ever find the issue Jayden I’m having the same issue
