Results 1 to 8 of 8
Thread: dual batteries & dual voltage sensing relays
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    After adding a 190w panel to the roof and a Victron 75/15 smartsolar MPPT to specifically charge the Aux battery, I added a 2nd voltage sensing relay to help maintain the cranking battery when the patrol is parked in the sun for long periods.
    So both batteries will connect to the other when their voltage is over 13.3v & disconnect when under 12.8v.
    I'm in the process of running 8mm2 cable to the fridge to help minimize voltage drop when compressor is on.
    I like it, all I need now is a decent aux battery
    2008 CRD Auto Wagon
    Ballarat, Vic
    175 Post(s)
    Sounding good, but I'd suggest that 8mm2 may be a bit light unless the fridge is pretty close to the battery. I would use a minimum of 8AWG which is 10mm2. Also if you are expecting cable induced voltage drop when you have the compressor running, do you have the compressor & fridge on the same circuit? If so I would advise a separate circuit for each.
    I have just run two new circuits in our truck. One just for Starlink running direct of 12v (12v to 47v converter) from a circuit breaker rated at 16 amps, & the other to run an Engel freezer & my Cpap machine from a 10 amp circuit breaker. Both using 8AWG/8B&S cable.
    I'm kinda hoping that you have used the same gauge cable & wrongly assumed it is 8mm2?
    Nov 2019
    Perth
    5 Post(s)
    sorry by compressor I meant the one in the fridge.
    I used to have a 3rd battery in the back right next to the fridge with a separate dc-dc charger but used that battery in another project and now want to simplify things in the car and just stick with the two under the bonnet.
    I've already bought the 8AWG cable so if I have issues I'll have to either double it up or get bigger stuff
    2008 CRD Auto Wagon
    Ballarat, Vic
    175 Post(s)
    Quote Originally Posted by pollenface View Post
    Ah my mistake re compressor. Doh!
    If it's 8AWG & not 8mm2 it'll be fine.
    Nov 2019
    Perth
    5 Post(s)
    apparently 8awg is 8.3mm2, 7awg is 10.5mm2
    https://www.rapidtables.com/calc/wire/awg-to-mm.html
    2008 CRD Auto Wagon
    Ballarat, Vic
    175 Post(s)
    Hmmmm, I may have got it wrong based upon this…. https://www.multicable.com/resources...ce-awg-to-mm2/
  8. #7
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    There is a lot of confusion and mis-use with wire gauges and sizes. According to the old standard, 8 SWG is 12.97 mm2, 8 AWG (also B&S) is 8.36 mm2. There is also 8 BWG (not common now) 14.79 mm2.
    The only way to be absolutely sure what you have is to measure and count strands and calculate the total cross sectional area.
    Then there is the 'automotive' way of referring to size by 3mm, 4mm etc which doesn't appear to directly relate to either wire diameter, copper diameter or cross sectional area.
    The best way to purchase electrical wire is to go by copper cross sectional area only and ignore all the rest.
  9. The Following 5 Users Say Thank You to Brissieboy For This Useful Post:
    BrazilianY60 (20th June 2024), Cuppa (18th June 2024), Hodge (17th June 2024), PeeBee (17th June 2024), Winnie (20th June 2024)
  10. #8
    Nov 2019
    Perth
    5 Post(s)
    I've got a voltage drop calculator on my phone which shows AWG/B&S and mm2 ... so i understand that at least
    2008 CRD Auto Wagon
