Results 1 to 3 of 3
Thread: Car top boat & loader
    Sep 2011
    Mount Annan
    Good morning all,
    Is there anybody carrying a car topper boat and electric loader. Thinking of adding one to my 2005 GU IV 4.2td
    If there is what loader and what boat are you carrying.
    What is the weight of both, and can someone tell me what weight can be carried on the roof of my vehicle.
    Cheers n beers
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Roof loading is a bit of an issue. I have seen lots of different limits from supposedly reliable sources. First check your handbook - some models do have it in there I have been told. There is nothing stated in my handbook so I tried to get a definitive answer from Nissan for my 2015 GU wagon and they gave me the following response:
    It also depends on the rack which should have limits specified, and all values need to be de-rated for off-road use.
    I hope that helps.
  3. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    mihit (5th May 2023), shakey55 (9th May 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    My old "standby" formula was 100kg/pair of roof racks. (Gutter mount)
    So if you have 5 Bars...technically you can put 250kg up there. Whether that's safe or sensible in terms of mass-height-handling...
    You'll get a lot of leverage up there as well and while a tinny/ dinghy may be aerodynamic going forwards - it will be something of a sail in cross wind.
    If you have rails, then you will need to investigate there, but should be approximate.
    1989 LWB 5-Seat, TD42
  5. The Following User Says Thank You to mihit For This Useful Post:
