Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Westy's 3rd draw build.....
    So after running the removable table idea for a bit I got frustrated quickly with it. The legs kept dropping down and jamming in the tailgate gap.
    So ripped that idea out and flipped it.
    I raised the fridge slide about 80mm, and built a draw for under it to house the stove and cutlery.
    I'm glad I've done this as it's so much more usable now as a all in one system..
    I have also put in the majority of the electronics.
    I've used a 8 way switch gang setup.
    The main fuse panel is on the side of the draws, with the buttons up top.
    Best bit is its blue tooth so I can switch lights off from the tent lol.
    Also a bit of weight reduction in the last pick..
  2. The Following 6 Users Say Thank You to BigRAWesty For This Useful Post:
    BrazilianY60 (27th May 2024), Cremulator (28th May 2024), jff45 (28th May 2024), MB (28th May 2024), MudRunnerTD (27th May 2024), Touses (28th May 2024)
  3. #12
    334 Post(s)
    Looks good mate, Did you cut those bottom holes to shed weight or drop a sink in? Mine is a fair bit heavier than your i reckon! LOL I am going to go hard with a 150d hole saw anywhere i can to save weight and just cover with carpet. I wont be able to shed heaps but any will be a winner. Thank god for airbags! lol
  4. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (28th May 2024), MB (28th May 2024), Stropp (28th May 2024)
  5. #13
    Reduce weight.
    That panel is the floor which is bolted in.
    And yea I used 12mm structural ply. It going be a lighter than formply lol.
  6. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
