Results 1 to 5 of 5
Thread: Noob member alert - ZD 30 to 4.2TDi conversion
    May 2021
    Hi Iím James or Patrol Jim as my username. Iíve had a CRD GU VII and Iíve just bought a 2003
    ST-L ZD30 that is a sight to behold...however The old girl needs a new spring in her step. I have a 2003 factory auto trans and a 06 Black top low kmís and I need a little help before I take the leap. My question is, does the trans need any adaptor plate or do I need a TD 4.2 Bell-housing between the Manual engine and auto trans. Also do I need to change the diff gears for engine breaking? If so what ratio. Iím sure this subject is covered in the forum somewhere, if somebody could share the link, that would be beaut. 👍 good to be part of the crew! Patrol Jim
    Patrol God Dhuck's Avatar
    Nov 2010
    Marsden Heights - I live on a hill
    5 Post(s)
    Welcome to the forum mate.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    7 Post(s)
    The ZD30 bell housing will bolt directly to the TD42 block but youíll need to do this modification for the TD starter motor.
    You have to drill & tap the 3 holes and remove a bit from the original starter holes. You can use the TD backing plate as a template.
    John
    Feb 2011
    Shed
    41 Post(s)
    G'day mate, welcome aboard
    Morayfield, QLD
    7 Post(s)
    On the subject of diff gears, I run the original 3.9 in mine and find it good. Some like it to rev harder on the highway but Iím at 1850 rpm @ 100 km/h with TC manually locked. 2000 rpm @ 110.. Less engine noise and pulls easily from there when needed.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    Rossco (4th May 2021)
