@poddy UltraGauge EMPlus _ IMO is good kit and yes does display boost pressure (absolute and gauged) from MAP sensor (cold side cooler) via ECU. Example of one page that I use. Price has dropped from $149 couple of yrs ago.
Last edited by Bidja; 27th November 2020 at 07:01 AM. Reason: Edit to link back to UltraGauge
pollenface (29th November 2020)
It's not the glow plugs; I've swapped the set and nothing changed. Not a damn thing. But yea, I see where you were coming from. 2 were no good anyway, sothat would have to be done anyway. Thank you
K, I don't think it will be the relay; I've had the multimeter hooked between battery (-) terminal and a tip of one of the NEW glow plugs, and it behaved like they describe in the manual that it should. It had around 11V when priming, opr when the glow plug little light on the dash was on. And it would return to 0V when the little dash light went out. So I made an assumption this behaviour is correct. Please do correct me if I am missing something. Many thanks.
Yep, this is the next patient for Dr. Poddy. Thank you so much for that link; I'll post back when done.
On it.
I'll move onto the fprv tomorrow and then see how that goes. I'll keep you posted. Thanks everyone.
PeeBee (28th November 2020)
That's a good looking unit!
2008 CRD Auto Wagon
@poddy the UltraGauge (EMPlus) that I procured does not support air intake temp, not all gauges / parameters can be accessed. Access @ user level (us) is limited by what access Nissan allows. Not sure if the UltraGauge MX gauge variant provides access to the parameter. Would be interested in reading this as well and also AFRs_maybe someone else might chime in with more insight on a suitable gauge or a smart phone App that can support air intake temp.
I bought the gauge direct from the US via their web page (linked provided earlier). Yes the gauge is pretty well a plug and play, you just need to select the gauges that you want to view on each of the 5 pages (total of up to 8 gauges per page). One thing to note is that, if U wish to view torque (N-m), the load gauge has to follow (next) to the torque gauge (refer my earlier post (shows torque gauge and then eng load). You have to know the max torque produced from your eng (eg: from dyno), key that in and torque then is calculated / displayed as a factor associated against the eng load.
Edit_thought you asked if the UltraGauge could read intake air temp_now cannot see your post, Never mind responded anyway. Post #20 refers found it_all good.
thanks mate.
And also big thanks to everyone that chipped in this thread. Problem sorted. I re-edited the first post with the resolution.![]()
