GQ patrol Aluminum fan shroud to suit
Suit 2 inch body lift only, TD42 will work with fan and radiator upgrades
Replaces usually damaged plastic shroud using factory mounts
full alloy laser cut and tig welded all hardware supplied.
They have a removable bottom section to allow easy fitment.
Looks beautifully made GQDrifter Mate[emoji106][emoji106]
Why a 2” body lift though, me and my dear mates chassis sliders shit ourselves at a mere 2” suspension lift hanging off the edge of some teetering tall Razorbacks :-)
Snuck some 35s under her has 2” body and suspension was the cheaper option for me rather than replacing all the suspension underneath and doing it properly with drop boxes and everything.
Since doing body lift always find all the little things that need fixing that you don’t think about when you do it originally. Was fighting with overheating for a bit after lifting it up combined with the bigger tyres but shroud made a huge difference when crawling up and along tracks.
