Results 1 to 7 of 7
Thread: Bad oil leak
    Dec 2019
    Bad oil leak
    Hi guys, I have a 2011 manual 3l CRD. I've just noticed there's an oil leak which I suspect started last night or this morning, but it has emptied out almost all the oil. Any ideas what it might be from? Thanks
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Is that the harmonic balancer? Front main seal?
    Dec 2019
    I'm not 100% sure, it's just been gushing out since around this morning
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by M.Johnson View Post
    It's a little hard to see what's going on, and I'm not used to looking at the 3l.. But looks like it's all coming from around the balancer.
    Pop over and introduce yourself and I'm sure someone with a bit more knowledge than me will come along and help you out.
  5. #5
    Beginner Bundy1's Avatar
    Jun 2016
    Sydney
    looks like front main seal...but grab some degreaser or oven cleaner give it a clean..start it up should be able to see it pretty quick if that only started afew days ago
  6. #6
    Sep 2018
    queensland
    my guess would be the front timing cover, ive seen many zd30 crd leak from the main timing cover sandwich plate.
  7. The Following User Says Thank You to Fireblade For This Useful Post:
    Hodge (5th December 2019)
    177 Post(s)
    Quote Originally Posted by Fireblade View Post
    Yup.
    Same, my money is on the timing cover.
