Results 1 to 4 of 4
Thread: Gq rear window removal how to do it ?
    Expert First Pooy's Avatar
    Mar 2018
    Looking at removing the rear windows in my 92 gq patrol any tricks to getting it out so far I can not work out how to get the windows out first I have the sliding set up
    From the inside you really just need to Push out. start in a corner and lift the rubber seal and start working around. You can keep the window closed, makes no difference. you will have it out in under 5 minutes. Scary how easy it is actually.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    First Pooy (6th July 2018)
    Mar 2018
    Thanks Mudrunner once I realized that the whole assembly comes out together it come out easily and yes it is scary how easy it comes out, the real problem was getting it back in what a nightmare, the rubber just kept tearing and I started tearing my hair out lol
    May 2025
    Southern nsw
    Thank you for the information
