Results 1 to 9 of 9
Thread: Won't start
    Nov 2016
    Won't start
    Hi, thanks for the add, I have a 2002 3lt Patrol that has a brand new battery but will not turn over fast enough to start any ideas? Thx
    330 Post(s)
    Has it just started doing it? Has it been getting worse or all of a sudden?
    If it turned over it should start. The NATS (Nissan Anit THeft System) cuts off the fuel solenoid on teh back of the pump and it could be your problem.
    474 Post(s)
    Welcome aboard Spook58 !
    I'm sure someone with descent lecky advice will be along shortly to assist mate. My only guess would be solenoid thingy issues off your starter motor mate?
    330 Post(s)
    @Yendor might be able to guide you mate, I have experienced this on a TD42 but not a ZD30. Search the forum for NATS and or Immobiliser fault and you will find some info. When did you fit the battery?
  6. #5
    Does it turn over slowly?
  7. #6
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  8. #7
    Nov 2016
    any luck on starting?
  9. #8
    Expert Corsta0211's Avatar
    Oct 2016
    Brisbane
    Hey mate, welcome to the forum.
    1989 GQ TD42 N/A.
  10. #9
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome mate. If its turning over slowly, it may be the starter nmotor atself or corrosion on the 12v main lead or terminal causing high resistance. After trying a couple of time, check the terminals at the starter motor end and the battery end and see if they are hot. that would indicate a high resistance joint.
