Page 95 of 96 FirstFirst ... 93949596 LastLast
Results 941 to 950 of 958
  1. #941
    476 Post(s)
    I’m happy with the rear carrier I made too.
  2. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (16th September 2024), Cremulator (16th September 2024), MB (16th September 2024), Rossco (16th September 2024)
  3. #942
    Put some new H4’s in. Hopefully better than the candles I had burning before.
    What's the verdict on these mate, I'm looking at getting something better for the clubsport..
  4. #943
    176 Post(s)
    These are the ones I've been using since I've owned Patrols (11 years?). Can rate them highly for vision and very long lasting too.
    https://www.narva.com.au/products/48...t-globes--bl2-
  5. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (30th November 2024)
  6. #944
    Jun 2018
    25 Post(s)
    My recommendation, after using higher wattage bulbs in the GU – go straight to Stedi copperhead LED bulbs. You will not regret it.
  7. #945
    476 Post(s)
    So as of late the kettle has been boiling faster than usual.
    So I’ve removed the fan, hub, water pump, radiator, thermostat fans and power steering cooler, and all the old foam seals. Time for a big clean out and overhaul.
    There’s a lot going on in front of the radiator.
  8. #946
    476 Post(s)
    Mudski GU Build Thread
    Everything’s out. The JPC high flow water pump is finally back in.
    Both thermo fans are off and I pressure washed the a/c condenser out. I washed it from the engine side to the outside. The roller door the Patrol was parked I. Front of copped a few bug from the condenser.
    BrazilianY60 (9th December 2024)
  10. #947
    476 Post(s)
    Wire band hose clamps! Why oh why!?
    Touses (2nd December 2024)
  12. #948
    476 Post(s)
    The parasitic current draw is back! I go to start the Patrol yesterday after being parked for 2 weeks and the battery is completely dead. The hunt is back on.
  13. The Following 3 Users Say Thank You to mudski For This Useful Post:
    AB (11th December 2024), BrazilianY60 (9th December 2024), PeeBee (10th December 2024)
  14. #949
    476 Post(s)
    God! Time to start pulling fuses!
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #950
    198 Post(s)
    Mark, this device might be a bit less cumbersome, I bought a cheapie like this and a more expensive unit - I also have some leaks and plan to dive into root cause as well.
    https://www.ebay.com.au/itm/395301005433
    The more expensive unit I sourced from the UK has a higher amp value, circa 80amp from memory but this parasitic load is going to be easility handled by this cheper unit provided it has the resolution I guess
  17. The Following User Says Thank You to PeeBee For This Useful Post:
    mudski (13th December 2024)
