Page 95 of 95 FirstFirst ... 939495
Results 941 to 947 of 947
  1. #941
    471 Post(s)
    I’m happy with the rear carrier I made too.
  2. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (16th September 2024), Cremulator (16th September 2024), MB (16th September 2024), Rossco (16th September 2024)
  3. #942
    Put some new H4’s in. Hopefully better than the candles I had burning before.
    What's the verdict on these mate, I'm looking at getting something better for the clubsport..
  4. #943
    176 Post(s)
    These are the ones I've been using since I've owned Patrols (11 years?). Can rate them highly for vision and very long lasting too.
    https://www.narva.com.au/products/48...t-globes--bl2-
  5. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (30th November 2024)
  6. #944
    Jun 2018
    25 Post(s)
    My recommendation, after using higher wattage bulbs in the GU – go straight to Stedi copperhead LED bulbs. You will not regret it.
  7. #945
    471 Post(s)
    So as of late the kettle has been boiling faster than usual.
    So I’ve removed the fan, hub, water pump, radiator, thermostat fans and power steering cooler, and all the old foam seals. Time for a big clean out and overhaul.
    There’s a lot going on in front of the radiator.
  8. #946
    471 Post(s)
    Mudski GU Build Thread
    Everything’s out. The JPC high flow water pump is finally back in.
    Both thermo fans are off and I pressure washed the a/c condenser out. I washed it from the engine side to the outside. The roller door the Patrol was parked I. Front of copped a few bug from the condenser.
  9. #947
    471 Post(s)
    Wire band hose clamps! Why oh why!?
    Touses (2nd December 2024)
